Brief Description: Control column mounts. F-606 bulkhead.
Today I lightened the F-633 control column mounts using drawing from the RV-9. I took it to the scotchbrite wheel and cleaned up the edges. This isn't called out for in the RV-6 drawing, but it has become common practice in newer models.
I located the 3/4 X 1" aluminum angle that makes up F-606C and drilled it to the F-606B bulkhead. I used the F-627L seat rib as detailed in the Frank Justice instructions to position the angle. I then assembled the F-628 and F-629 assemblies. Unfortunately, I wasted some time drilling the 3/4 X 3/4" angle on the F-629 assembly. I'll have to redo the angle tomorrow.
