Brief Description: Control mount and seat belt anchors
I installed the F-634 seat belt anchors to the F-605 bulkhead. I made sure to number them in order to guarantee proper placement later on. I had to slightly clearance the mounting flanges on the far outer anchors. This is due to the angle bent into the F-605C bars.
I also partially assembled the control column and drilled the F-633 control column mount to the F-604 bulkhead.
