I received a few things in the mail and got to work utilizing them. I installed the K-1000 platenuts on the F-601Z firewall doubler. I also used a reamer on the bushing in the control stick assembly (DWG 41) to allow me to assemble the control assembly. I will need to ream it a bit larger. I'll also need to work on the tolerances a bit to allow smooth operation.
One of the things that took the longest today was clearancing those bushings. They are intended to be slightly longer than the part that they are in (Wd-611). This allows the bolt to be torqued without binding. I had to tap them out, grind, tap them back in and repeat until perfect. Tedious process for me....
