cleaned up the window channel and did a trial fit. Worked well. I had planned on doing the forward side also but after some thought I will wait . I will make a template for the forward side blocking prior to permenently gluing in the window and then add the forward blocking . The reason is that due to the window and channel angles it makes it very nice to pull the window forward just slightly and the window pulls out easily. On the other hand this glue is going to set fast by placing the window forward then sliding it back into position it forces the window to seat nicely all around its perimiter.
