The manual calls for blocking all around the rear windows .the upper and lower stringers provide coverage for most of the perimeter . To make the curves small blocks must be set to handle the complex curvers of both fuse and window. I had already done similar work on the coaming and came up with a better way. I decided to make a laminate of 1/16 ply to form these areas.
Peviously I had marked the inside of the window perimeter to locate the upper stringer . The windows rear profile provided the template for the laminates. I simply rolled the window on a sheet of ply while marking its outline , meaured back 1/2 for my rear cutline and made six pieces from that template .
Both aft laminates (12 pcs ) were cut from remnants of 1/16 birch ply
