continued blending everything together , I protected the windshield with duct tape along the lower work area and while set in place brought the filler up to the windsceen. After everything was cured the windscreen was removed and the body work began. After the contour was cut in on the fairing blocks , I pressed west epoxy and micro through all the seems , gaps and low spots on the interior row of blocks , Weather proofed the dash and applied a protective coat of west over the fairing and foward upper fuse.
