Brief Description: Instrument panel and fwd structure
Permanent install of instrument panel rod and instrument panel bow. Weather proofed area , set the panel in a bed of dry micro , and seated with AN3-12 , wood washer and metal locknuts.
Permanent install of instrument panel bow . Set the panel bow permenantly at 9.5 inches , bedded the bow bottoms onto the longeron and angle with dry micro and seated with -19 flush bolt washer and lock nut.
Glued in firewall horizontal - top ripped at 5 degrees . T-88
