Push rod tube was cut to 17 3/8 to square up the control tubes to 21 1/4 (per pivot ref) with half threads remaining for adjustment .After fitting it was apparent that more material needed to be removed for the rod ends to clear. Material was removed from both sides at the radius of the channel . Debured and stress relieved all welds. Blasted with a fine media to provide a good profile for powder coat . Powder coated white.
