Barracuda
Barracuda
Center section
7-9-2008
secondary door hinges
door hinges with bushings installed - shoulder bolts will be used as hinge pins . door set in place with 3/32 shims and taped down to locate position on rib .
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
