Removed tip rib hardware in prep for skinning lower center section. Trimmed up tip rib hardware during removal - finished to final size. determined that there was some play in the gear spar with all hard ware removed . The gear spar must be glued to the skin in its exact position - so reinstalled the tip rib to gear spar angles with a spacer used to represent the tip rib plate .
