Barracuda
Barracuda
Center section
11-4-2007
center rib
laminate center rib
lay up center rib lamination . These lamination require a large amount of T-88 about 2 pints after testing for the end rib laminations all pieces being laminated need to be wetted out with epoxy.
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
