Brief Description: center section straps/ diehidal
Cleaned up excess web with router,cut in seat pan relief. layed out spar for bushings and straps . Made strap fixture B. Alighned straps to location. Marked / double checked bushing positions ( lined up to my initail layeout) bored all lower bushing holes bothe left and right. Holes were bored .020 under 5/8 good press fit . All bushings are 1/32 under the shear web surface. Re mount staps to there marked locatons - drill ,ream and install bolts. Note - landing gear mounting pivot points were not reamed at this time per manual. Assemble spars together with shear pins clamp upper straps in place .
