everything went as per the manual except I had not yet installed the upper and lower hinge angles . The manual calls for angles to be set in place - then set the fin up on blocks to work on the ribs .The nose of F2 is dead on per the rib template on 600 but I find the width shy by about 3/16 when assembled to the leading edge , all other ribs sit well on the LE .
