Barracuda
Date:  7-25-2007
Number of Hours:  3.00
Manual Reference:  sht 602
Brief Description:  elevator Trim servo install
I decided to move the elevator horn to accomadate servo position. This seems to be the best choice with the only draw back being that the trim tab horn is not going to be removable . The plus is that besides the servo being placed in a position that is servicable , a drag reduction will be gained in that there will be a minimal space between tab and elevator. I am also incorporating flush inspection plates.
mounted
mounted
position thru inspection opening
inspection plate / push rod
