Barracuda
Barracuda
wing outer panels
10-21-2007
outer panel straps - install starps
This was a very methodical procedure , you only get one shot at this to get it right.
Straps measured for location on bushings and layed out , position locked in place with locating fixture . All bushings drilled thru to 15/64 then reamed to 1/4 .
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
