I made 4 outboard plates , I did this because it was easier and for whatever reason - I make some form of error cutting the rear spar strap slots upon install - I would then have options - after the outboard plates are fitted properly - I will trim the remaining two plates to spec for inboards.Note : I had more than carefully checked and rechecked all measurements from WCP for the end rib plates. I cross referenced several plan pages for accuracy. There appears to be a error with the dimentions or parts call out for Detail "D" on sheet 200 - Rear spar to end rib attach angles . I made the angles in mached sets per "D" - forward lenght is 5.125" aft 5.00" (image 3) . As you can see in image 2 the aft attach angle exceeds the plate layout lines. I cross checked and scaled the angles from sheet 202 the fwd angle checks in at 5.125 the aft at aproximatley 4.50" .I expect upon assembly that I will have to remake new aft angles.
