Barracuda
Barracuda
powder coat main gear
powder coated upper mains and lower mains . two coats white
Note : powder coat will be used as a base for imron - its the hardest coating I know of and even very difficult to bead blast off. Imron will be applied afted wet sanding .
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
