applied the inspection hole doublers . I made these doublers when I built up the center section skin. The pilot hole for the center line was drilled when I cut out the skin inspection hole and pin locations were made for each doubler so that they could be located on center and glued later . The doubler also provides a flange mounting surface for a flush inspection plate.
