cut a "C" shape for the secondary gear doors .025 T2024 x 1.250 for the secondary gear door seal and attached with t-88 ans # 4 SS. counter sunk wood screws. Made and attached upper main door gear seals with same material and attached in same fashion . The screws in this piece are temporary and will be replaced with counter sunk rivets after the T-88 cures . a similar seal will be made for the upper secondry door.
The plan here is to fair the seals in and provide a smooth airflow .
