line sanded root to tip rib, contoured upper main spar to airfoil profile. Attached RT outer panel to set strap location . Used a piece of scrap 1/8 in sheet to set the outer strap angle , clamped strap to mahogony block in proper position . drilled and reamed thru straps and angle installed 1/4 dia bolt.
