Barracuda
Barracuda
rear strap locate /end rib install
Set strap location with outer panels on - removed outer panels . cut end ribs and notched for straps . End ribs glued to main spar with T-88
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
