Barracuda
Date:  2-9-2008
Number of Hours:  4.00
Brief Description:  Fairing ailerons to outer panels
Fairing in the ailerons to thier outer panels to make final placement of aileron hinges to the rear outer panel rear spar . Also note that on the plans - the bellcrank bearings used for the ailerons hinges scales out to .500 wide , However , the current or todays bellcrank bearing measuers 11/16 th in width - almost an additional .250 increase in width - this places the mounting bolts for the hinge on the rear outer panel just inside the hardpoint mounts - . The plans call for 1 inch wide mahogany - I would suggest these be at least 1.375 wide each side of rib .
I will correct this by adding to both sides w T-88 . The bolt will be in the origional block but I want to eliminate any possibility of the bolts pulling or working out the side.
note position of hinge mounting hole and hardpoint
