Barracuda
Barracuda
center section spar - glueing
Trail fit all 3 pieces . made all the blocks . Cut out the 1 3/4 radius with the band saw for each side Glued the entire assembly. Cut the inside angle from radius to wing to body attach block on band saw . Check fit , glue with T-88.
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
