Barracuda
Barracuda
secondary spars
glued up last fwd spar. Cleaned up cap strips with a router and flush trim bit on the other three. Will do the same for the last one when dry. Layed out the lightning holes also will drill all when last one is dry also.
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
