Changes - 1. plan call out for brakets .062 alum 2024-t3 changed to .125 2024-T3 angle and added bushingsfor smooth operation .2. plan calls for 1/16 th roll pins for stops - changed to 1/4 dia. shaft collars - filed flats for collar set screws - additionally tack welded the out stop collar .about one hour total time for fabrication - rework - the initial .062 brackets were tossed - they flexed with friction or drag - hence the heavier material and bushings.
