The canopy plex arrived today ! Time to get back to work . Two things that have come up that need addressed . When the windshield was placed the lower window line had changed - the change was due to the sika primer line . In other words the lower visual astetic line of all the windows will as currently laid out have a visual step down from the windshield line to the canopy window line . Its just not going to flow visualy. The second problem is that the hendricks door handle/latches are not going to fit in the canopy door vertical space that is currently present in the lower door frame.
Solution - remove ply from lower canopy doors , raise lower canopy attach points , re fit with new attach points and ply. This will fix both the lower window line and add space for the hendricks door handles .
Removed lower ply from canopy frames with router depth set just above the the spruce framing.
