Barracuda
Barracuda
rear window
pilot side rear canopy window
after the lower stringer had set and cured yesterday the top stringer position was marked and glued in .
Both stringers were epoxied with T88
Test fit the window and its just a bit snug , which was planned , the window can be retrimmed but not streched .
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
