Barracuda
Barracuda
engine mounts
engine mount fabrication
Made the eight 1x1x1/8 squares for the mount tube ends and stack drilled them 1/4 " at this time .
Fitted squared to ends of tube with 1/4 inch thru bolt , for welding .
These were sent to the machine shop for tig welding .
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
