Cut stringers for rear fuse . Had to use large squares clamped to HFD line on fuse and clamp station 152 with a strong back to make sure it stayed true . Used String lines to pull 152 and 234 tight for glueing in stringers. Added 3/8 x 3/8 blocking to ends . Glued with T-88
