Locate pedal assembly on fuse longeron, measure 3 inches from firewall, this is the minimum setting. Drill three sets of holes for pedal placement. Make center support fron supplied angle. cut area for clearence. deburr part. Drill for mount. Fit center bearing block, drill mounting holes and cut block in half. Very neat seeing some assemblies coming to life.
