Mark's Helicycle Build
Date:  7-3-2017
Number of Hours:  6.00
Brief Description:  Trim Fin Work
Final riveting was done on the vertical trim fins. The horizontal fin work was begun. The horizontal fin was trimmed to match the vertical fins and initial holes were drilled and riveted to attach the internal spar. Magnets were used to line up the tubing with the drilled holes.
Trailing edge riveted. Attachment bolt in placd
Drilling holes for horizontal fin rivets
Riveting of lower vertical fin trailing edge
