Mark's Helicycle Build
Date:  6-6-2017
Brief Description:  Cyclic Grip and Rotor Shaft Alignment Housing
Work was done to preliminarily install all collective and cyclic contols in the Helicycle. This is very detailed work with lots of measuring and remeasuring to make sure everything lines up. Initial work on the transmission group was started.
Cyclic grip prepped and painted
Attachment holes drilled for alignment housing
Alignment housing in place
