Mark's Helicycle Build
Helicycle
Trim Fin Assembly
The trim fin corrosion proofing is dry and the final riveting of the fins to the vertical spar was done. It should be noted that the tubing was much easier to insert in to the bottom trim fin after the zinc chromate was applied.
Corrosion proofing done
Initial riveting of trim fins
Trim fins mostly riveted
Helicycle Home
266
Airframe
Delivery/Inventory
Instructional Videos
Lubrication
Tail Rotor
Transmission
Trim Fins
Upholstery
Windscreen
