Marks KitLog
Date:  6-2-2016
Number of Hours:  1.00
Brief Description:  Rough cut, Router cut Stabilator/Rudder Ribs
Rough cut stabilator and rudder ribs.
Router cut stabilator ribs to with "former" rib made earlier this month. As you can see the router table is working nicely.
Rudder ribs must be carefully sanded (on another day) to finish dimensions as no "former" was made because all are different.
In addition I was able to rough cut the F-3 and F-4 1/4'' plywood, will leave it rough until it is epoxied to bulk heads and will then use router to get it exact.
