Brief Description: Measured & laid-out tailpost and vertical fin
Measured & laid-out tailpost and vertical fin - had to combine drawings with Gary's rudder - Gary's rudder hinges are 30.5" O.C. (vs. 29.1875" on plans) - adjusted inner tailpost to match existing rudder x- will have to re-drill lower hole on outer tailpost to match rudder as well - cut temporary bushing and screwed tailpost to bench to hold perpendicular
Just realized I will NOT have to re-drill hinge holes because Gary's rudder went with vertical pins thru bushings welded-on
