Marks KitLog
DR-107
Test weld cluster #2
- switched back to No.2 tip for wider weld puddle
- flame set neutral JUST makint hissing noise
- filled bead
- went back over and moved puddle consistently
- cut-off tubes after welding completed
Cody's VP-1 Home
DR-107 Home
744
Ailerons
Belly Tank
CAD
Control Linkages
Control Stick
Cowling
107
FAA
Fuel Tank
150
Harness
INSPECTIONS
Instruments & Panel
Pedals
Plans
Research
Seat
SolidWorks
381
228
Spar
Tailwheel
Welding
Tailwind Home
