Marks KitLog
DR-107
Removed Vacuum Pump, installed cover plate
Removed Vacuum Pump
Installed cover plate AEL60430
with gasket
nuts & washers snug-tight
-1.8 lbs
Cody's VP-1 Home
DR-107 Home
744
Ailerons
Belly Tank
CAD
Control Linkages
Control Stick
Cowling
107
FAA
Fuel Tank
150
Harness
INSPECTIONS
Instruments & Panel
Pedals
Plans
Research
Seat
SolidWorks
381
228
Spar
Tailwheel
Welding
Tailwind Home
