Marks KitLog
Date:  1-20-2017
Number of Hours:  0.75
Brief Description:  Measured & laid-out tailpost and vertical fin
- had to combine drawings with Gary's rudder
- Gary's rudder hinges are 30.5" O.C. (vs. 29.1875" on plans)
- adjusted inner tailpost to match existing rudder
x- will have to re-drill lower hole on outer tailpost to match rudder as well
- cut temporary bushing and screwed tailpost to bench to hold perpendicular
Just realized I will NOT have to re-drill hinge holes because Gary's rudder went with vertical pins thru bushings welded-on
