Marks KitLog
DR-107
DR7-1-904-3
Began modeling wing ribs with NACA0016
DR7-1-904-3 (Nose rib at 12.25
DR7-1-904-9 (Mid rib at 15.00
DR7-1-904-15 (Aft rib at 15.00)
Lightening holes
Construction lines for centers of stringer cut-ots
NOTE: Need to adjust aft spar - it's off a bit
NOTE: Double-check chord length on 15.00 - seems short@1480.5mm
Cody's VP-1 Home
DR-107 Home
744
Ailerons
Belly Tank
CAD
Control Linkages
Control Stick
Cowling
107
FAA
Fuel Tank
150
Harness
INSPECTIONS
Instruments & Panel
Pedals
Plans
Research
Seat
SolidWorks
381
228
Spar
Tailwheel
Welding
Tailwind Home
