Marks KitLog
DR-107
Tip Tank Attach Fittings
Designed Tip Tank Attach fittings
- plate-tube-band design thought to be too heavy
- re-designed simple spar box to fit over extended wood spar(s)
- spar box will also act as a baffle and reinforcement inside tank
Cody's VP-1 Home
DR-107 Home
744
Ailerons
Belly Tank
CAD
Control Linkages
Control Stick
Cowling
107
FAA
Fuel Tank
150
Harness
INSPECTIONS
Instruments & Panel
Pedals
Plans
Research
Seat
SolidWorks
381
228
Spar
Tailwheel
Welding
Tailwind Home
