Marks KitLog
Date:  3-19-2013
Number of Hours:  0.60
Brief Description:  Tested Joint-2 to failure
- bottom capstrip clamped in vise
- leverage from 1.5" PVC pipe
- force applied in twist
Failure #1 at top capstrip (tension)- (epoxy joint pulled wood apart at the grain)
Failure #2 at lower portion (compression) of gusset (epoxy joint held and gusset failed uniformly)
I'm happy and have confidence in joints and that strength of epoxy joint exceeds strength of the wood.
