Brief Description: Tested sample glue joint to failure
Tested sample glue joint to failure - unprepared pieces of 2X lumber - NOT sanded before epoxy - Tee joint placed in vice - held 30 lbs. fine - failed at 65 lbs. - pulled wood fibers apart - glue joint held
