Marks KitLog
Date:  3-14-2013
Number of Hours:  1.50
Brief Description:  Re-designed Root Rib per Jim Stanton's comments
- "Root rib upper curve from mid-chord aft should perfectly match main ribs"
SolidWorks:
- copied main rib sketch
- overlaid root rib sketch on top to use identical main rib geometry
- 2" spacing lines per Jim C's drawing
- smoothed upper spline curve
- used same vertical stick locations
- revised diagonals to intersect at junctions
- doubled rear verticals at main spar per Jim Stanton's suggestion to allow for wing attach fitting cut-out & retain strength
- plan on solid nose block per Stanton's manual
