Modeled Root Rib (JimC-revised) completely - measurements from TE instead of LE - 24" spar center-to-center - rear spar center located same distance from TE as on Main Ribs - spar openings are 1/16" + 1/16" wider than on main ribs to allow for mahogony plywood doublers
