Modeled Right Wing assembly in SOlidWorks - noted errors on ACS23 (spar root attach fittings both forgot ply doublers) * Front spar attach inside should be 1-3/8" (not 1-1/4" shown) * Rear spar attach inside should be 1-1/8" (not 1" shown)
Still need to adjust rib spacing (too far out toward tip) to match strut attach doublers correctly positioned
Also need to adjust front spar attach fitting to correct width
