Marks Nynja - Queensland
Date: 6-20-2012
Number of Hours: 0.50
Brief Description: Ztron Labs Fuse Board
Recieved my latest copy of Kitplanes today, and with reading it through I got to the classifieds section/advertisers section at the rear of the book and found an interesting little advertisement for a company called Ztron Labs, Headed over there and had a look, I was in the process of sorting out fuses and I found this little device, essentially its a fuse bus, with touch buttons, that can be programmed to whatever you would like it to be Fuse wise, so if you need a 2.5A Fuse up to a 20A Fuse, with a maximum capacity of 50A per board.
The Entire unit weighs in at 50 grams, Total, so I thought to myself for the cost and weight of this, especially when Avaition fuses are about $40-50 each, the cost was justified as well as the weight. also on the site I've found a VERY lightweight master bus relay, So when turning the master switch on, this unit can switch the battery load to the panel and then 'Liven' the aircraft, again light and easy, hopefully some of these weight savings will translate into a bit more useful load, but I suspect that I will be using this to put in more Gizmo's for my piece of mind!
http://www.ztronlabs.com/products.php
Touch Fuse!
Master Relay
