Marks Web Site
Date:  11-11-2023
Number of Hours:  3.00
Manual Reference:  15-5
Brief Description:  Right & Left Aft ribs drill for conduit (15-5)
I finished up priming the doublers and stiffening fork. I also made a decision on where to add the holes for the conduit. I created a template to make the center in the same spot on each rib, then removed it (not yet rivetted on) and drilled a #40 hole, followed by the step drill to 0.75 diameter for the conduit. The outer most 3 ribs on each wing have a different hole pattern, so I had to adjust the position slightly. The conduit will have a slight kink as it transitions along the wing from rib #13 to rib #12 (#1 being the most inboard rib and #15 being the most outboard rib). I’m ready to start attaching the ribs to the spar. I would typically put the shop head on the thinner material (rib side), but that would make it hard to remove, if I ever need to, and more difficult for the rivet gun access. I’ve seen several builders put the factory head on the spar side and buck from the rib side.
Rear spar doubler plates primed (23-149)
Rear spar doubler forks primed (23-150)
0.75” Hole drilled for conduit (23-151)
