Marks Web Site
Date:  10-14-2023
Manual Reference:  15-5
Brief Description:  Left wing rear spar (15-5)
I went ahead and drilled the rear spar and aft ribs as directed. It clears the original holes, but not by much…maybe ¼” on center between the original hole and the new holes. Only on one rib, the other has plenty of distance between holes. I also riveted all the brackets together and clecoed everything to the rear spar for final drilling. I completed the countersinks on the inboard doubler plate, but still need to countersink the top flange of the rear spar. This required flipping the assembly over so I can have better access to the top side.
Countersunk holes on inboard rear spar doubler plate (23-126)
Doubler fork holes matched drilled through spar and rib flanges (23-127)
Outboard aileron bracket clecoed in place and final drilled (23-129
