Marks Web Site
Date:  10-6-2023
Number of Hours:  3.00
Manual Reference:  15-4
Brief Description:  Left wing rear spar (15-4)
I drilled the holes in the doubler plates for the rear spar and traced the hole for the controls. I also deburred everything and primed it. For the control hole, I marked the center, drilled a started hole then use the step drill to cut most of it away. I then followed up with the sanding drum on the Dremel. The final step was to cleco it back to the spar and clean it up until both matched. I also primed the aileron bracket hardware, so it’s now ready to rivet.
Rear spar doubler match drill (23-116)
Rear spar doubler match drill (23-117)
Doublers deburred and primed (23-120)
