Marks Web Site
Date: 9-30-2023
Number of Hours: 2.00
Manual Reference: 15-2
Brief Description: Aileron hinge brackets (15-2)
I can’t believe it’s been over month since my last entry. I picked up an added responsibility to teach Seminary in the mornings to high school students before school, which requires prep time that I used to use for building. It’s all good, I will find some time, but it may slow the build a little. Before finishing up section 14, where I attach the aft ribs to the spar, I wanted to make sure I made allowance to run all the wires and tubing. Since I purchased the Dynon pitot tube with AoA, then I need to drill an extra set of holes to run the tubing. I also bought some conduit to run wires through the wing, so I’ll need to add some holes for that. The other things I bought were the fuel float sending units for both fuel tanks, ADAHRS shelf for the Emp and the aileron trim kit. As far as making progress on the build, I deburred all the aileron brackets, final drilled the holes and added some countersinks around the bearing.
Aft ribs clecoed in place, thinking about wire/tubing runs (23-111)
Aileron brackets with counter sink holes (23-112)
More brackets (23-113)
